Group: DynoMotion Message: 9328 From: yan.tatarintsev Date: 3/13/2014
Subject: Trouble with StraightFeed
Hi!
I have unexpected reset to 0.0 on all 6 coordinates when use
CCoordMotion::StraightFeed.
I do:
G0 X500 Y500 C0
Then - PC program with
sprintf(chCmdMove, "%s%f", "Move5=", fAngle*(180.0/PI)*p->CountsPerInchC);
CM->DoKMotionCmd(chCmdMove, true);
Now all great.
But when I do
int nDrillResponse =
CM->StraightFeed
0.5,
fTargetXMillimeters/25.4, fTargetYMillimeters/25.4, fDestZMillimeters/25.4,
fDestAMillimeters/25.4, fDestBMillimeters/25.4, fDestCDegrees,
0, 0
all the coordinates falls to 0.0,
and only then - moves to the task values.
Help, please...
Group: DynoMotion Message: 9329 From: yan.tatarintsev Date: 3/13/2014
Subject: Re: Trouble with StraightFeed
Now I see -
int CCoordMotion::GetDestination(int axis, double *d)
returns me wrong values.
Is it function gets the current position on axis?
Group: DynoMotion Message: 9330 From: Tom Kerekes Date: 3/13/2014
Hi Yan,
The Coordinated Motion Library Current Positions need to be synchronized to your current starting position.   Sorry our example should have included this.  Try adding:
    int result = CM->ReadCurAbsPosition(&CM->current_x,&CM->current_y,&CM->current_z,
                                                          &CM->current_a,&CM->current_b,&CM->current_c,true);
Add this before the call to the first StraightFeed().
Group: DynoMotion Message: 9331 From: Tom Kerekes Date: 3/13/2014
Hi Yan,
This returns the current commanded destination, not the measured encoder position.  It should return the same value that is currently on the KMotion Axis Screen Destination for the Axis.
